Zum Hauptinhalt wechseln
Dell inspiron 15 5502 Memory modules Replacement
Was du brauchst
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
  1. Dell inspiron 15 5502 Memory modules Replacement, Screws: Schritt 2, Bild 1 von 1
    • In the back there are 9 screws.
    • (captive) M2x7.5
    • M2x4
    • Unscrew these and store in a safe place. (eg: nescafe cup, container )
  2. Dell inspiron 15 5502 Memory modules Replacement, Getting the base cover out: Schritt 3, Bild 1 von 1
    • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: Schritt 5, Bild 1 von 2 Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: Schritt 5, Bild 2 von 2
    • The sticker and the cable connector(below the sticker)
    • Peel the tape and disconnect the battery cable from the system board.
  4. Dell inspiron 15 5502 Memory modules Replacement, Drain the power: Schritt 6, Bild 1 von 1
    • Press and hold the power button for five seconds to ground the computer and drain the flea power.
  5. Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: Schritt 7, Bild 1 von 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: Schritt 7, Bild 2 von 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: Schritt 7, Bild 3 von 3
    • Where I am talking about.
    • Lift the mylar to uncover the memory module.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  6. Dell inspiron 15 5502 Memory modules Replacement, Removing: Schritt 8, Bild 1 von 1
    • Remove the memory module from the memory-module slot.
    • Store the Ram sticks safely in an anti-static bag.
Ziellinie
Android Alliance Mitglied von Android Alliance
Community
83 Mitglieder
670 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 335
