Einleitung
To replace the battery you will need a sharp edged tool, be sure to be careful. The glue on the battery is sticky and hard to get off.
  1. With a J00 Philips head screwdriver, unscrew the two 4mm black screws  located at the bottom of the device.
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels. Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Carefully lift back panel away from the body of the device.
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  5. Desolder positive and negative, red and black,  wires from the mother board that are connected to the battery. The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
    • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
    • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
  6. Using a metal spudger tool, wedge between battery and metal screen. Follow the  edge of the battery to loosen the glue.
    • Using a metal spudger tool, wedge between battery and metal screen.
    • Follow the edge of the battery to loosen the glue.
  7. Once the glue is loosened, you should be able to pry off the battery from the screen. Using your hands, pull up on the battery to pull battery off.
    • Once the glue is loosened, you should be able to pry off the battery from the screen.
    • Using your hands, pull up on the battery to pull battery off.
    • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
    • The battery will be completely disconnected and you can set the battery aside in a safe place.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Faith Lebo
180 Reputation
1 Anleitung geschrieben
the replacemet has 3 wires .where go the 3 wire?
javier perez - Antwort
were can i buy a new  bettery
Theresa - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 3,317
