Zum Hauptinhalt wechseln
DigiTech RP70 DC Power Connector Replacement
Was du brauchst
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: Schritt 1, Bild 1 von 2 DigiTech RP70 DC Power Connector Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: Schritt 2, Bild 1 von 2 DigiTech RP70 DC Power Connector Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: Schritt 4, Bild 1 von 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: Schritt 5, Bild 1 von 1
    • Desolder the back of the motherboard where the power connector is located.
Abschluss
Ein Kommentar
Later? I cant see to other
ISAAC SALAZAR - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 324
