Zum Hauptinhalt wechseln
DigiTech RP70 Input/Output ¼” Ports Replacement
Was du brauchst
  1. DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: Schritt 1, Bild 1 von 2 DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Input/Output ¼” Ports  Replacement: Schritt 2, Bild 1 von 2 DigiTech RP70 Input/Output ¼” Ports  Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Input/Output ¼” Ports  Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Input/Output ¼” Ports  Replacement: Schritt 4, Bild 1 von 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: Schritt 5, Bild 1 von 2 DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: Schritt 5, Bild 2 von 2
    • Desolder the back of the motherboard where the damaged input/output port is located.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 312
