Einleitung
To replace the Digiland DL1168A battery you will need an opening tool. Be sure to be careful. The glue on the battery is sticky and hard to get off.
Was du brauchst
Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
Desolder the four wires connecting the rear case to the motherboard.
Disconnect the wires from the motherboard.
Remove the rear case from the device.
Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
Using an opening tool, separate the battery from the tablet.
Follow the edge of the battery to loosen the glue.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
