Einleitung
This guide will be showing you how to replace the charging port for the Digital2 D2-861G model. Be sure to carefully remove parts to avoid damaging the device.
Was du brauchst
Insert spudger in the slot below the micro SD card.
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Locate the gold colored ZIF (Zero insertion force) connector and disconnect it from the motherboard.
Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
Remove two 3.51mm screws that are located on the top corners with your Phillips #00 screwdriver.
Next, unplug the ZIF connector by going under the black tab and simply lift up.
Slide the connector out with the pointed side of the spudger.
Insert the pointed side of the spudger in the corner and gently lift.
Once one side is lifted, use your fingers and with little force, lift up to remove the case.
To remove the motherboard, grab the component on the top left and gently lift while pushing or pulling to the right.
To replace the charging port, you can either replace the motherboard or desolder the port.
