Zum Hauptinhalt wechseln
Digital2 D2-861G Speaker Replacement
Was du brauchst
  1. Digital2 D2-861G Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards
  2. Digital2 D2-861G Speaker Replacement: Schritt 2, Bild 1 von 2 Digital2 D2-861G Speaker Replacement: Schritt 2, Bild 2 von 2
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Speaker Replacement: Schritt 3, Bild 1 von 3 Digital2 D2-861G Speaker Replacement: Schritt 3, Bild 2 von 3 Digital2 D2-861G Speaker Replacement: Schritt 3, Bild 3 von 3
    • Look at the images to locate the black tabs.
    • Carefully remove the tape to avoid damaging the device.
    • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
    • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
  4. Digital2 D2-861G Speaker Replacement: Schritt 4, Bild 1 von 2 Digital2 D2-861G Speaker Replacement: Schritt 4, Bild 2 von 2
    • Make sure to not bend or puncture the battery when removing it.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
    • Use prying tools to carefully break the adhesive under the battery
  5. Digital2 D2-861G Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 Digital2 D2-861G Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Be sure to have a magnetic mat or anything magnetic to hold your screws!
    • Now that you have removed the battery, proceed to removing the two 3.51mm screws with your Phillips #00 Screwdriver.
    • Carefully lift the casing and pull back the tape along with the soldered wire.
    • You can remove the soldered wire if you want or leave it connected. Refer to iFixit's Wie man Lötverbindungen herstellt und entlötet guide.
  6. Digital2 D2-861G Speaker Replacement: Schritt 6, Bild 1 von 1
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 129
