Zum Hauptinhalt wechseln
Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement
Was du brauchst
  1. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, External Cover: Schritt 1, Bild 1 von 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 2, Bild 1 von 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 3, Bild 1 von 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, Front/Rear Facing Camera: Schritt 4, Bild 1 von 1
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  5. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 5, Bild 1 von 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  6. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 6, Bild 1 von 1
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  7. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: Schritt 7, Bild 1 von 1
    • Finally remove the cameras.
Abschluss
UMass Dartmouth, Team 5-6, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 103
