Zum Hauptinhalt wechseln
Digitech XC- 5206 Buttons Replacement
Was du brauchst
  1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: Schritt 1, Bild 1 von 2 Digitech XC- 5206 Buttons Replacement, Speaker Buttons: Schritt 1, Bild 2 von 2
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Buttons Replacement: Schritt 2, Bild 1 von 3 Digitech XC- 5206 Buttons Replacement: Schritt 2, Bild 2 von 3 Digitech XC- 5206 Buttons Replacement: Schritt 2, Bild 3 von 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Buttons Replacement: Schritt 3, Bild 1 von 1
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  4. Digitech XC- 5206 Buttons Replacement: Schritt 4, Bild 1 von 3 Digitech XC- 5206 Buttons Replacement: Schritt 4, Bild 2 von 3 Digitech XC- 5206 Buttons Replacement: Schritt 4, Bild 3 von 3
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 154
