Zum Hauptinhalt wechseln
Dirt Devil Scorpion Quick Flip Motor Replacement
Was du brauchst
  1. Dirt Devil Scorpion Quick Flip Motor Replacement, Motor: Schritt 1, Bild 1 von 1
    • Gently remove filter adapter from the vacuum body by pressing the gray plastic release button.
  2. Dirt Devil Scorpion Quick Flip Motor Replacement: Schritt 2, Bild 1 von 1
    • Place the vacuum body on its left side and remove all 4mm screws with a Phillips #1 screwdriver.
  3. Dirt Devil Scorpion Quick Flip Motor Replacement: Schritt 3, Bild 1 von 1
    • Carefully take apart the shell of the vacuum body.
    • Cut the two wires attached to the motor and remove the motor from the body.
  4. Dirt Devil Scorpion Quick Flip Motor Replacement: Schritt 4, Bild 1 von 1
    • Solder the wires from the replacement motor to the wires connecting it to the power cord.
    • Carefully place the replacement motor back into its correct position in the vacuum body.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 506
