Einleitung
In order to open up the Surface 3, you will need to use the iOpener to loosen up the adhesive under the display screen, then use the picks to get under the screen and "pry" it open.
Was du brauchst
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
