Einleitung
This guide has been updated by iFixit staff! Read the new, official guide here.
Was du brauchst
Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
Then, out pops the battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
