Einleitung
This will walk you through the steps necessary to access crucial parts inside the Teac DC-D2831, to make adjustments or repairs. Electronics are delicate, so be sure to take caution when making modifications and during reassembly. Needle nose pliers are a must for removing the snap ring!
Before beginning this repair, turn off your stereo and unplug it from the power outlet.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Lift the lid to get to the turntable.
Using the appropriate tools (needle-nose pliers, tweezers, screwdriver, etc.), remove the snap ring from the center of the turntable. The snap-ring is the small metal ring around the axel of the turntable.
Gently lift the turntable from the rest of the device.
If the device has a faulty belt, see the belt repair guide here: Belt Repair Guide
Remove the screws on the side of the device using a Phillips #2 screwdriver.
When removing the screws, take note of which screws go where.
27.0mm
19.8mm
12.0mm
If the device is having motor issues, continue here: Motor Repair Guide.
If the device is having issues with the display, continue here: Volume Control Knob.
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
How to remove lid from CD-D2831
So radio sound and tape work and sound is great. However when turn table is on the sound is low only on that component any help would be greatly appreciated
