Zum Hauptinhalt wechseln
Disconnecting Microphone from Motherboard
Was du brauchst
  1. Disconnecting Microphone from Motherboard, Front and Back Cover: Schritt 1, Bild 1 von 2 Disconnecting Microphone from Motherboard, Front and Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Disconnecting Microphone from Motherboard: Schritt 2, Bild 1 von 2 Disconnecting Microphone from Motherboard: Schritt 2, Bild 2 von 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Disconnecting Microphone from Motherboard, Microphone Connection: Schritt 3, Bild 1 von 2 Disconnecting Microphone from Motherboard, Microphone Connection: Schritt 3, Bild 2 von 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
Abschluss
Cal Poly, Team 12-34, Amido Spring 2013 Mitglied von Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
This guide doesn’t show a motherboard and is a copy of this other guide (for a webcam):
Logitech Webcam Pro 9000 Microphone Replacement
Maximilian Cohan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,638
