Zum Hauptinhalt wechseln
Dragon Touch A1x Plus Battery Replacement
Was du brauchst
  1. Dragon Touch A1x Plus Battery  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Battery  Replacement: Schritt 2, Bild 1 von 2 Dragon Touch A1x Plus Battery  Replacement: Schritt 2, Bild 2 von 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Battery  Replacement: Schritt 3, Bild 1 von 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Battery  Replacement: Schritt 4, Bild 1 von 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Battery  Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Battery  Replacement: Schritt 6, Bild 1 von 2 Dragon Touch A1x Plus Battery  Replacement: Schritt 6, Bild 2 von 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
Abschluss
Josh Null
313 Reputation
3 Anleitungen geschrieben
IUPUI, Team S5-G5, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
where can you find a replacement battery for this tablet?
Lupe Rdrgz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 1,819
