Einleitung
Following this guide will allow you to replace the motherboard of your Dragon Touch Y88X Plus. This repair requires the use of a soldering iron. Be very cautious during the soldering process. The iron gets very hot and can cause injury. For more information on soldering, see the How to Solder and Desolder Connections guide.
Was du brauchst
Remove the back case using a plastic opening tool or spudger.
Start at the corners and work your way around the perimeter of the tablet.
Desolder the wires connected to the motherboard to disconnect the battery and speaker.
Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
Use a spudger to slide the ribbon cables from the connectors.
Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
