Zum Hauptinhalt wechseln
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: Schritt 1, Bild 1 von 3 Draining a Toilet Tank, Tank Lid: Schritt 1, Bild 2 von 3 Draining a Toilet Tank, Tank Lid: Schritt 1, Bild 3 von 3
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 1 von 2 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 2 von 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: Schritt 3, Bild 1 von 2 Draining a Toilet Tank, Draining a Toilet Tank: Schritt 3, Bild 2 von 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
Abschluss
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
Eine weitere Person hat diese Anleitung absolviert.
Ron Davis
31.439 Reputation
13 Anleitungen geschrieben
2 Kommentare
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - Antwort
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 42
Letzte 30 Tage: 193
Insgesamt: 32,922
