Einleitung
Follow this guide to replace the motherboard and midframe assembly on a Sony Dualshock 4 CHU-ZCT2U PlayStation controller.
Was du brauchst
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
Use a pair of tweezers to disconnect the touch panel ribbon cable.
11 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
I have followed the steps with an ifixit replacement board, but the controller doesn't stay on after connecting via bluethoot, and the usb connection is not working either, i've checked with the damaged board and all of that is working correctly.
Is there any additional steps to make it work? Did i received a faulty board?
Update to this comment, the battery was dead, so as of now, it is just the usb port that doesn't work, but just with the replacement board, it is brand new from ifixit store, so i'm still thinking it is faulty.
