Zum Hauptinhalt wechseln
EVGA x17 Scroll Wheel Replacement
Was du brauchst
  1. EVGA x17 Scroll Wheel Replacement, Scroll Wheel: Schritt 1, Bild 1 von 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Scroll Wheel Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Scroll Wheel Replacement: Schritt 3, Bild 1 von 1
    • Remove the weight chamber cover.
  4. EVGA x17 Scroll Wheel Replacement: Schritt 4, Bild 1 von 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Scroll Wheel Replacement: Schritt 5, Bild 1 von 2 EVGA x17 Scroll Wheel Replacement: Schritt 5, Bild 2 von 2
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Scroll Wheel Replacement: Schritt 6, Bild 1 von 1
    • Carefully slide middle section out.
    • Remove smaller sized cross head screws from piece labeled AZAC001-A V1.0.
  7. EVGA x17 Scroll Wheel Replacement: Schritt 8, Bild 1 von 1
    • Pull the transistor from the side of the mouse wheel.
  8. EVGA x17 Scroll Wheel Replacement: Schritt 9, Bild 1 von 1
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
  9. EVGA x17 Scroll Wheel Replacement: Schritt 10, Bild 1 von 2 EVGA x17 Scroll Wheel Replacement: Schritt 10, Bild 2 von 2
    • Remove scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue).
Abschluss
Sydney Puett
569 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 84
Insgesamt: 422
