Einleitung
If your duck’s speaker sounds disoriented or has stopped working properly, your duck may have experienced water damage and you will need to replace the speaker. This guide will assist you with properly opening the duck and replacing the speaker.
Please note, this guide requires desoldering. For more instructions on how to solder and desolder connections, please see this guide.
Was du brauchst
Using the plastic opening tool, pull up the black tab up until it stops.
Pull up the white cable tab up slowly
Use the J1 bit to unscrew all four screws attached to the motherboard.
Use the J1 bit to unscrew both 9 mm screw attached to the white plastic plate.
Lift up the motherboard and speaker, and place to the side like done so in the image.
Take the speaker and by using the soldering iron, unsolder by the red and white wires.
Replace the new speaker and solder the two wires back into place. The red wire goes on the left and white wire goes on the right.
