Zum Hauptinhalt wechseln
Element GC-1020 Battery Replacement
Was du brauchst
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: Schritt 1, Bild 1 von 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: Schritt 2, Bild 1 von 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: Schritt 3, Bild 1 von 2 Element GC-1020 Battery  Replacement, Battery: Schritt 3, Bild 2 von 2
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Lashaun Noel
591 Reputation
5 Anleitungen geschrieben
University of Tampa, Team 1-4, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-4, Whiteside Fall 2015
UT-WHITESIDE-F15S1G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 334
