Zum Hauptinhalt wechseln
Ematic FunTab 3 Battery Replacement
Was du brauchst
  1. Ematic FunTab 3 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 3 Ematic FunTab 3 Battery Replacement, Back Panel: Schritt 1, Bild 2 von 3 Ematic FunTab 3 Battery Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    Frag FixBot
    Kommentar hinzufügen
  2. Ematic FunTab 3 Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the back panel away from the screen.
    Frag FixBot
  3. Ematic FunTab 3 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the black tape to reveal the wire ribbon connector.
    Frag FixBot
  4. Ematic FunTab 3 Battery Replacement: Schritt 4, Bild 1 von 3 Ematic FunTab 3 Battery Replacement: Schritt 4, Bild 2 von 3 Ematic FunTab 3 Battery Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
    Frag FixBot
  5. Ematic FunTab 3 Battery Replacement: Schritt 5, Bild 1 von 3 Ematic FunTab 3 Battery Replacement: Schritt 5, Bild 2 von 3 Ematic FunTab 3 Battery Replacement: Schritt 5, Bild 3 von 3
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
    Frag FixBot
  6. Ematic FunTab 3 Battery Replacement: Schritt 6, Bild 1 von 2 Ematic FunTab 3 Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    Frag FixBot
Abschluss
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 986
