Zum Hauptinhalt wechseln
Ematic Genesis Battery Replacement
Was du brauchst
  1. Ematic Genesis Battery Replacement, Ematic Genesis Casing: Schritt 1, Bild 1 von 3 Ematic Genesis Battery Replacement, Ematic Genesis Casing: Schritt 1, Bild 2 von 3 Ematic Genesis Battery Replacement, Ematic Genesis Casing: Schritt 1, Bild 3 von 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Ematic Genesis Battery Replacement: Schritt 2, Bild 1 von 3 Ematic Genesis Battery Replacement: Schritt 2, Bild 2 von 3 Ematic Genesis Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Ematic Genesis Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove back plate from screen plate and lay both down flat next to each other.
  4. Ematic Genesis Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Ematic Genesis Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Ematic Genesis Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
  5. Ematic Genesis Battery Replacement: Schritt 5, Bild 1 von 3 Ematic Genesis Battery Replacement: Schritt 5, Bild 2 von 3 Ematic Genesis Battery Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
    • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
  6. Ematic Genesis Battery Replacement: Schritt 6, Bild 1 von 1
    • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
    • If not replacing the battery, do NOT disconnect the wires.
    • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
    • Wie man Lötverbindungen herstellt und entlötet
Abschluss
Baylor, Team 4-3, Williams Spring 2015 Mitglied von Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
tienen el firmware disponible?
Danny Abreu Victoriano - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,151
