Zum Hauptinhalt wechseln
Ematic eGlide 4 Motherboard Replacement
Was du brauchst
  1. Ematic eGlide 4 Motherboard Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Motherboard Replacement: Schritt 3, Bild 1 von 2 Ematic eGlide 4 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Motherboard Replacement, Speaker: Schritt 4, Bild 1 von 1
  5. Ematic eGlide 4 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port on the screen board.
  7. Ematic eGlide 4 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port.
    • If you have already removed the side button array you do not need to do this step.
  8. Ematic eGlide 4 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
  9. Ematic eGlide 4 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Desolder the Wi-Fi Adaptor
    • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
    • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
  10. Ematic eGlide 4 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Desolder the battery connections
    • If not replacing the motherboard or battery, omit this step
  11. Ematic eGlide 4 Motherboard Replacement: Schritt 11, Bild 1 von 2 Ematic eGlide 4 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
    • Lift the motherboard out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Bailey Hughes
617 Reputation
6 Anleitungen geschrieben
Baylor, Team 5-8, Williams Spring 2015 Mitglied von Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 267
