Zum Hauptinhalt wechseln
Envizen V100M Speakers Replacement
Was du brauchst
  1. Envizen V100M Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 2 Envizen V100M Speakers Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Speakers Replacement: Schritt 2, Bild 1 von 3 Envizen V100M Speakers Replacement: Schritt 2, Bild 2 von 3 Envizen V100M Speakers Replacement: Schritt 2, Bild 3 von 3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Speakers Replacement, Speakers: Schritt 3, Bild 1 von 1
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. Envizen V100M Speakers Replacement: Schritt 4, Bild 1 von 1
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Envizen V100M Speakers Replacement: Schritt 5, Bild 1 von 1
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
Abschluss
nbach
663 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Duarte Spring 2015 Mitglied von UMass Dartmouth, Team 3-2, Duarte Spring 2015
UMASSD-DUARTE-S15S3G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 99
