Zum Hauptinhalt wechseln
Epson PowerLite Home Cinema 1040 Air Filter Replacement
  1. Epson PowerLite Home Cinema 1040 Air Filter Replacement, Air Filter: Schritt 1, Bild 1 von 1
    • Turn off the projector and unplug the power cord.
  2. Epson PowerLite Home Cinema 1040 Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Locate the air filter cover located on the top of the projector on the nearest side adjacent to the lens
    • Remove the air filter cover by gripping the ridge underneath it and pulling upwards
  3. Epson PowerLite Home Cinema 1040 Air Filter Replacement: Schritt 3, Bild 1 von 1
    • Pull the air filter out of the projector by gripping the black tab on the top of the air filter
    • The air filter contains ABS resin and polyurethane foam; dispose according to local regulations
  4. Epson PowerLite Home Cinema 1040 Air Filter Replacement: Schritt 4, Bild 1 von 1
    • Push the new air filter gently into place until there is a click
Abschluss
Utah Tech University, Team 1-6, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-6, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 105
