Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Device Overheats
The device becomes abnormally hot during operation.
Dirty Air Filter
One of the most common causes for an overheating device is a clogged or dirty air filter. This reduces air flow to the projector, thus reducing the effectiveness of the cooling fan. If the air filter is clogged or dirty, it will need to be cleaned or replaced.
Dirty Or Broken Cooling Fan
If the cooling fan is filled with dust or other debris, it will limit its ability to cool the projector and can cause the projector to overheat. The fan could also be entirely unoperational, in which case it may need to be replaced.
No Gap Underneath Projector
The projector is designed to be placed on a flat, hard surface and has four pads to raise the projector and allow air to flow beneath the unit. Ensure there is a gap underneath the projector to allow passage of air beneath the unit.
Nothing Projects on Screen
The device appears to be on, but no images are projected to the screen.
Lens Cover is Closed
The front of the projector has a sliding door that covers the projector lens. It is labeled with black text on the top of the projector spelling “A/V Mute” on the closed side, and “Open” on the open side. Ensure that the black slider is on the side labeled “Open”, and you can see the projector lens.
Loose or Disconnected Cables
Ensure that all cable connections are plugged in and secure in place including the power cable and any input cables. Press the Menu button to see if the menu appears. If the menu appears, it points to an issue with the input device or input device cables.
Input Device Improperly Set Up
Ensure the input device is displaying an image or video, not a blank screen or screensaver. Make sure the brightness on the input device is turned up. Press the Source Search button on the projector, and make sure the source selected is the same source being used by the input device.
Lamp is Burned Out
If there is no light being emitted from the projector at all, the lamp may be burned out and needs to be replaced. See the replacement guide here.
Dust, Specks, and Dark Spots on Projector Image
The device is powered on and displaying the desired image, but there are small pieces of the picture missing.
Overheating
Brown or black smudges can be a result of improper cooling and overheating of the Epson PowerLite Home Cinema 1040. Without taking it apart, attempt to clean the device, paying more attention to the critical areas that involve the cooling and ventilation of the projector.
Dirty Lens
Turn the Epson PowerLite Home Cinema 1040 off and clean the projector lens with a fiberglass cloth.
Part of Projector Image is Black or Missing
The device is fully powered on, but only displays part of the desired image.
Lens Path is Obstructed
Verify that there are no pieces of debris on the lens of the projector itself. If there is nothing on the projector, then begin to make sure that there are no other objects in the room that could be possibly blocking the projection along its path to the screen.
Lens Cover is Partially Closed
Ensure that the sliding lens cover of the Epson Powerlite Home Cinema 1040 is fully open before use. Having the lens cover completely closed will prevent any picture from being shown, but it is also possible for this cover to slide partially out and obstruct a smaller piece of the projection.
Projector Image is Dull or Dim
The device has powered on and is displaying the desired image, but the projection appears too dim and is difficult to see.
Brightness Settings Are Too Low For Room
Ensure that the device is projecting in a sufficiently dark room, and that the brightness of the projector is turned up to an appropriate level. Give time for image to come up; it should be visible within a few minutes of turning device on.
ECO Mode is Enabled
When the device is in ECO mode, its power consumption is reduced and the brightness is lowered. To disable ECO mode, press the Menu button on the top of the projector, and navigate to ECO. Then, change the Power Consumption setting from ECO to Normal.
Damaged Bulb
If the image is dim, it is possible that the bulb is burnt out or damaged. Inspect the bulb for any obvious damage, and replace it if necessary.
No Inputs Recognized By Epson PowerLite Home Cinema 1040
The device has powered up, but does not project any of the desired inputs or connections.
Inputs Are Obstructed by Debris
There may be dust or debris blocking the input cables from making a full connection. Attempt to remove any debris that may be obstructing the input sockets.
Input Cables Not Secured
Ensure that all plug-in sockets on the Epson Powerlite Home Cinema 1040 are in proper functioning order, and snugly hold the input cord from the input device. Try to avoid jostling the Epson Powerlite Home Cinema 1040 during use to keep all of the connections secure.
Flickering Screen Light
The screen blinks when turned on.
Damaged Bulb
Check to see if the bulb is burnt out or damaged; if it is damaged, replace the bulb.
Dust Build Up
If issues persist, dust build up within the Epson PowerLite Home Cinema 1040 may be the cause. Open the Epson PowerLite Home Cinema 1040 and remove dust with dry fiber cloth.
Loose Cables
Loose cables cause incomplete connections. Press the cables in firmly to create a better connection to resolve the issue.
Projector Does Not Output Any Sound
The projector itself does not produce any sound, even with the volume up.
Issue With Connected Audio Device
If you have an external speaker connected to your Epson PowerLite Home Cinema 1040, then the projector's built-in speaker will not output any sound. Disconnect all wired or wireless external speakers.
Volume Turned Down On Video Source
The volume level is controlled by both the projector and the source device. Ensure that the volume is turned up on both the Epson PowerLite Home Cinema 1040, as well as the device being used to play the content.
Broken Speaker
If the volume is turned up on both the source device and the projector, and there are no external speakers connected, then there is likely an issue with the built-in speaker and it may need to be replaced.
Projector Fan Constantly Runs
If your fans constantly turn on even when the lamp is cool, there could be an issue with the temperature sensor. A faulty temperature sensor can have an ohm reading of 0, thus reporting to the motherboard an infinitely high temperature reading. This causes the fans to constantly run and may even force the projector to shut off. Follow these steps to replace your temperature sensor.
0 Kommentare
