Einleitung
This guide details the process of an Equity Alarm Clock 13014 Alarm Switch Replacement. The alarm switch activates the alarm when it's set to go off. This guide requires some basic soldering.
Was du brauchst
Remove the battery door using your finger nail or an opening tool.
Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
Remove the small screw located below the alarm switch as well.
Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
Use a Phillips #1 screwdriver to reinstall the switch screws.
2 weitere Personen haben diese Anleitung absolviert.
