Zum Hauptinhalt wechseln
Fahrenheit FHT 125PRMR Motherboard Replacement
Was du brauchst
  1. Fahrenheit FHT 125PRMR Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove both hinge covers on each side of the flat iron.
  2. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using Philips head #2 remove the 7 mm black screw that was underneath one of the hinge covers.
  3. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 3, Bild 1 von 2 Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 4, Bild 1 von 2 Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using Philips head #1 remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using Philips head #1 remove the two 4 mm silver screws on the sides of dial panel cover.
  6. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 6, Bild 1 von 2 Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using Philips head #00 to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 8, Bild 1 von 2 Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove three 3 mm sliver screws #1 from the motherboard.
    • Use your hand to life the motherboard out of the flat iron.
  9. Fahrenheit FHT 125PRMR Motherboard Replacement: Schritt 9, Bild 1 von 1
Abschluss
MeKenzie Hilsmeyer
23 Reputation
1 Anleitung geschrieben
IUPUI, Team 2-2, Harley Fall 2016 Mitglied von IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 1,543
