Zum Hauptinhalt wechseln
Framework Desktop Secondary Storage Replacement
Was du brauchst
  1. Framework Desktop Secondary Storage Replacement, Power down your Desktop: Schritt 1, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Power down your Desktop: Schritt 1, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Power down your Desktop: Schritt 1, Bild 3 von 3
    • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
    • Make sure your Framework Desktop Screwdriver has the T5 Torx bit (labeled as T5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Desktop Secondary Storage Replacement, Remove the Handle: Schritt 2, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Remove the Handle: Schritt 2, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Remove the Handle: Schritt 2, Bild 3 von 3
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. Framework Desktop Secondary Storage Replacement, Remove the Top Panel screws: Schritt 3, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Remove the Top Panel screws: Schritt 3, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Remove the Top Panel screws: Schritt 3, Bild 3 von 3
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. Framework Desktop Secondary Storage Replacement: Schritt 4, Bild 1 von 3 Framework Desktop Secondary Storage Replacement: Schritt 4, Bild 2 von 3 Framework Desktop Secondary Storage Replacement: Schritt 4, Bild 3 von 3
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. Framework Desktop Secondary Storage Replacement: Schritt 5, Bild 1 von 3 Framework Desktop Secondary Storage Replacement: Schritt 5, Bild 2 von 3 Framework Desktop Secondary Storage Replacement: Schritt 5, Bild 3 von 3
    • Repeat the same procedure for the other Top Panel screw.
  6. Framework Desktop Secondary Storage Replacement, Remove the Top Panel: Schritt 6, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Remove the Top Panel: Schritt 6, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Remove the Top Panel: Schritt 6, Bild 3 von 3
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. Framework Desktop Secondary Storage Replacement, Remove the Right Panel: Schritt 7, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Remove the Right Panel: Schritt 7, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Remove the Right Panel: Schritt 7, Bild 3 von 3
    • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
    • Remove the Right Panel.
  8. Framework Desktop Secondary Storage Replacement, Reposition the Desktop: Schritt 8, Bild 1 von 2 Framework Desktop Secondary Storage Replacement, Reposition the Desktop: Schritt 8, Bild 2 von 2
    • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
  9. Framework Desktop Secondary Storage Replacement, Loosen the SSD screw: Schritt 9, Bild 1 von 2 Framework Desktop Secondary Storage Replacement, Loosen the SSD screw: Schritt 9, Bild 2 von 2
    • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
    • The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
  10. Framework Desktop Secondary Storage Replacement, Remove the SSD: Schritt 10, Bild 1 von 2 Framework Desktop Secondary Storage Replacement, Remove the SSD: Schritt 10, Bild 2 von 2
    • While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
  11. Framework Desktop Secondary Storage Replacement, Remove the secondary storage heat spreader screw: Schritt 11, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Remove the secondary storage heat spreader screw: Schritt 11, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Remove the secondary storage heat spreader screw: Schritt 11, Bild 3 von 3
    • If your SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise skip here.
    • While securing the secondary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
  12. Framework Desktop Secondary Storage Replacement, Remove the secondary storage heat spreader: Schritt 12, Bild 1 von 1
    • Lift the secondary storage heat spreader out of the Desktop and remove it.
    • Follow the guide normally, making sure to ignore instructions that involve the secondary storage heat spreader.
  13. Framework Desktop Secondary Storage Replacement, Disassembly complete: Schritt 13, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  14. Framework Desktop Secondary Storage Replacement, Install the SSD: Schritt 14, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Install the SSD: Schritt 14, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Install the SSD: Schritt 14, Bild 3 von 3
    • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • While holding the SSD heat spreader upright, align the SSD's gold contacts with its socket.
    • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
    • Lay the heat spreader back onto the SSD.
  15. Framework Desktop Secondary Storage Replacement: Schritt 15, Bild 1 von 1
    • Use your Framework Desktop Screwdriver to tighten the captive T5 Torx screw securing the SSD.
  16. Framework Desktop Secondary Storage Replacement, Reposition the Desktop: Schritt 16, Bild 1 von 2 Framework Desktop Secondary Storage Replacement, Reposition the Desktop: Schritt 16, Bild 2 von 2
    • Lift the Desktop so it sits upright on your work surface.
  17. Framework Desktop Secondary Storage Replacement, Install the Right Panel: Schritt 17, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Install the Right Panel: Schritt 17, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Install the Right Panel: Schritt 17, Bild 3 von 3
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Right Panel and the silver base.
    • Push the Right Panel towards the base of the computer to engage the clips.
  18. Framework Desktop Secondary Storage Replacement, Install the Top Panel: Schritt 18, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Install the Top Panel: Schritt 18, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Install the Top Panel: Schritt 18, Bild 3 von 3
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  19. Framework Desktop Secondary Storage Replacement: Schritt 19, Bild 1 von 2 Framework Desktop Secondary Storage Replacement: Schritt 19, Bild 2 von 2
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  20. Framework Desktop Secondary Storage Replacement, Install the Handle: Schritt 20, Bild 1 von 2 Framework Desktop Secondary Storage Replacement, Install the Handle: Schritt 20, Bild 2 von 2
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  21. Framework Desktop Secondary Storage Replacement, Install the top panel screws: Schritt 21, Bild 1 von 3 Framework Desktop Secondary Storage Replacement, Install the top panel screws: Schritt 21, Bild 2 von 3 Framework Desktop Secondary Storage Replacement, Install the top panel screws: Schritt 21, Bild 3 von 3
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  22. Framework Desktop Secondary Storage Replacement: Schritt 22, Bild 1 von 3 Framework Desktop Secondary Storage Replacement: Schritt 22, Bild 2 von 3 Framework Desktop Secondary Storage Replacement: Schritt 22, Bild 3 von 3
    • Repeat the same procedure for the other top panel screw.
  23. Framework Desktop Secondary Storage Replacement: Schritt 23, Bild 1 von 3 Framework Desktop Secondary Storage Replacement: Schritt 23, Bild 2 von 3 Framework Desktop Secondary Storage Replacement: Schritt 23, Bild 3 von 3
    • Use your finger to close the two D-rings on the top panel screws.
Abschluss
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
212.518 Reputation
1.037 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 28
Letzte 30 Tage: 109
Insgesamt: 419
