Zum Hauptinhalt wechseln
FujiFilm FinePix S5100 Battery Compartment Replacement
Was du brauchst
  1. FujiFilm FinePix S5100 Battery Compartment Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 3, Bild 1 von 1
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Battery Compartment Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 5, Bild 1 von 3 FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 5, Bild 2 von 3 FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 5, Bild 3 von 3
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 6, Bild 1 von 3 FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 6, Bild 2 von 3 FujiFilm FinePix S5100 Battery Compartment Replacement: Schritt 6, Bild 3 von 3
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
  6. FujiFilm FinePix S5100 Battery Compartment Replacement, Battery Compartment: Schritt 7, Bild 1 von 3 FujiFilm FinePix S5100 Battery Compartment Replacement, Battery Compartment: Schritt 7, Bild 2 von 3 FujiFilm FinePix S5100 Battery Compartment Replacement, Battery Compartment: Schritt 7, Bild 3 von 3
    • Remove the single 1.3mm Phillips #000 screw.
    • Carefully remove the battery compartment from the rest of the camera.
Abschluss
Kristen Gismondi
92.167 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.468 Anleitungen geschrieben
Ein Kommentar
Will this process be the same for the S3300 and can you recommend the best place to purchase a replacement part?
Lauren Higgins - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 868
