Zum Hauptinhalt wechseln
Fujifilm FinePix A350 Battery Contact Replacement
Was du brauchst
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: Schritt 1, Bild 1 von 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: Schritt 1, Bild 2 von 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: Schritt 1, Bild 3 von 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: Schritt 2, Bild 1 von 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: Schritt 2, Bild 2 von 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: Schritt 2, Bild 3 von 3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Abschluss
Jaxon Cramer
1.045 Reputation
9 Anleitungen geschrieben
Clemson, Team 6-4, Benson Spring 2016 Mitglied von Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Mitglieder
17 Anleitungen geschrieben
Ein Kommentar
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 494
