Einleitung
If the buttons on your Fujifilm FinePix T500 camera are unresponsive, the issue may be with the circuit board. Replacing the circuit board can restore functionality, but it requires careful handling of small components. Before you begin, make sure you have the necessary tools, such as a Phillips #00 screwdriver, spudger, soldering iron, and tweezers. Be cautious when working with internal electronics, as improper handling can cause further issues. Follow this step-by-step guide to safely complete the repair
Was du brauchst
Open the battery compartment and remove the battery.
Carefully pry the front half of the casing away from the camera.
Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
Lift the LCD screen out of the camera.
Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
Pry off the center casing of the camera. Separate the top and side sections individually before fully removing the casing.
Peel back the strip of black tape to reveal a red and black wire.
Detach the orange ribbon by gently pulling on it.
Detach the golden ribbon by gently lifting it with the spudger.
The lens should now be free to simply be pushed out of its socket.
The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to pull back the plastic covering the top of the camera.
Use tweezers to disconnect both the red and the black wires located next to the flash of the camera.
Use tweezers to disconnect the blue and white wires on the underside of the camera.
Desolder the red, black, and white wires from the circuit board that you pried off earlier.
2 weitere Personen haben diese Anleitung absolviert.
