Zum Hauptinhalt wechseln
Fujifilm FinePix Z1 LCD Screen Replacement
Was du brauchst
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 4, Bild 1 von 3 Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 4, Bild 2 von 3 Fujifilm FinePix Z1 LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
Abschluss
Carra
533 Reputation
4 Anleitungen geschrieben
Baylor, Team S2-G4, Johnson Spring 2018 Mitglied von Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 420
