Zum Hauptinhalt wechseln
Fusion5 5.5 Gen II Front & Rear Camera Replacement
Was du brauchst
  1. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: Schritt 2, Bild 1 von 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: Schritt 2, Bild 2 von 2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Front & Rear Camera Replacement: Schritt 3, Bild 1 von 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Front & Rear Camera: Schritt 4, Bild 1 von 1
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
  5. Fusion5 5.5 Gen II Front & Rear Camera Replacement: Schritt 5, Bild 1 von 1
    • Using the tweezers, grab the ribbon cable and pull it out from its connector.
    • Then pull the front camera component out of its socket on the motherboard.
  6. Fusion5 5.5 Gen II Front & Rear Camera Replacement: Schritt 6, Bild 1 von 1
    • Using tweezers, grasp the ribbon cable's metal tab and gently lift it to disconnect it from its connector on the motherboard.
    • Make sure to only lift by the metal tab and not the connector socket due to its susceptibility to break off.
  7. Fusion5 5.5 Gen II Front & Rear Camera Replacement: Schritt 7, Bild 1 von 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement: Schritt 7, Bild 2 von 2
    • You may now grab and lift the rear-facing camera out of its socket on the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 285
