Zum Hauptinhalt wechseln
GameStop Universal System Selector Button Replacement
Was du brauchst
  1. GameStop Universal System Selector Button Replacement, Button: Schritt 1, Bild 1 von 1
    • Disconnect the DC 6V IN power cable from the device.
    • Remove the three front panel screws on the bottom of the device using the Phillips #00 Screwdriver.
  2. GameStop Universal System Selector Button Replacement: Schritt 2, Bild 1 von 1
    • Carefully pry off the front panel of the device to reveal the button in need of replacement.
    • The outer piece of the device is plastic and may break it not carefully handled.
  3. GameStop Universal System Selector Button Replacement: Schritt 3, Bild 1 von 2 GameStop Universal System Selector Button Replacement: Schritt 3, Bild 2 von 2
    • Pull firmly on the button in need of replacement to free it from its housing.
  4. GameStop Universal System Selector Button Replacement: Schritt 4, Bild 1 von 1
    • Gently push the replacement button into the housing.
  5. GameStop Universal System Selector Button Replacement: Schritt 5, Bild 1 von 1
    • Snap the front panel back into place.
    • Replace the 3 front panel screws.
Abschluss
The system selector button should now be working properly. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
Jared
201 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-6, Vijaybhaskar Fall 2013 Mitglied von UMass Dartmouth, Team 4-6, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G6
4 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 565
