Einleitung
Removing the logic board from the Garmin Nuvi 200
Was du brauchst
Peel off the sticker from the bottom of the device to reveal two screws.
Insert a plastic opening tool in the gap between the front and rear casing.
Carefully work the tool around the gap, separating the two halves of the case.
Peel away the tape holding the ribbon cable in place.
Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
Remove the three screws from the logic board using the #00 Phillips screwdriver.
Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
