Zum Hauptinhalt wechseln
Garmin Nuvi 2589LMT Microphone Replacement
Was du brauchst
  1. Garmin Nuvi 2589LMT Microphone Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Microphone Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2589LMT Microphone Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Microphone Replacement, Microphone: Schritt 3, Bild 1 von 1
    • Using a soldering iron, desolder the wire connection at the two soldering points between the microphone and the motherboard to remove.
    • Learn more about soldering and desoldering connections here.
  4. Garmin Nuvi 2589LMT Microphone Replacement: Schritt 4, Bild 1 von 1
    • Using the angled tweezers, grab the microphone wires and gently pull to remove the microphone from the device.
Abschluss
Adam Ferraro
920 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 1-2, Nance Fall 2016 Mitglied von USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 Mitglieder
Ein Kommentar
Where do you buy the new microphone?
Rich Hollabaugh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 582
