Zum Hauptinhalt wechseln
Garmin Nuvi 2589LMT Speaker Replacement
Was du brauchst
  1. Garmin Nuvi 2589LMT Speaker Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Speaker Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2589LMT Speaker Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Wedge the speaker from the device, using the small plastic opening tool.
    • The speaker is held in place by adhesive tape on the outer rim. Because the speaker is still connected to the motherboard, pry the speaker away from the device gently.
  4. Garmin Nuvi 2589LMT Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using tweezers, remove the tape covering the speaker connection to the motherboard.
  5. Garmin Nuvi 2589LMT Speaker Replacement: Schritt 5, Bild 1 von 1
    • Using a soldering iron, desolder the wire connection at the soldering points between the speaker and the motherboard to remove.
    • Learn more about soldering and desoldering connections here.
Abschluss
Adam Ferraro
920 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 1-2, Nance Fall 2016 Mitglied von USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 Mitglieder
Ein Kommentar
What size was the speaker in inches or mm? How many ohms was it? Where did you find the replacement?
george.terbush - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 351
