Einleitung
You will need to remove several screws and the battery in order to replace the motherboard.
Was du brauchst
Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
Using a soldering iron, desolder the black and blue wires connected to the motherboard.
Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
