Einleitung
You will be removing several screws to get to the screen. Eventually, you will pop out the screen to replace it.
Was du brauchst
Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
Using a soldering iron, desolder the black and blue wires connected to the motherboard.
Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
2 weitere Personen haben diese Anleitung absolviert.
