Einleitung
Here you will be removing several parts of the device to get to the USB port.
Was du brauchst
Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
Using a soldering iron, desolder the USB port connected to the motherboard.
Check out this awesome guide on how to solder and desolder connections.
Eine weitere Person hat diese Anleitung absolviert.
