Zum Hauptinhalt wechseln
Garmin Nuvi 56LMT Speaker Replacement
Was du brauchst
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 56LMT Speaker Replacement: Schritt 2, Bild 2 von 2
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: Schritt 3, Bild 1 von 2 Garmin Nuvi 56LMT Speaker Replacement: Schritt 3, Bild 2 von 2
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: Schritt 4, Bild 1 von 2 Garmin Nuvi 56LMT Speaker Replacement: Schritt 4, Bild 2 von 2
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: Schritt 5, Bild 1 von 1
Abschluss
Dustin Saxon
228 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S3-G5, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 106
