Zum Hauptinhalt wechseln
Garmin inReach Explorer Plus LCD Screen Replacement
Was du brauchst
  1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover.
  3. Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 3, Bild 1 von 2 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: Schritt 4, Bild 1 von 2 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 5, Bild 1 von 2 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 6, Bild 1 von 2 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 7, Bild 1 von 3 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 7, Bild 2 von 3 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: Schritt 8, Bild 1 von 2 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: Schritt 8, Bild 2 von 2
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 9, Bild 1 von 3 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 9, Bild 2 von 3 Garmin inReach Explorer Plus LCD Screen Replacement: Schritt 9, Bild 3 von 3
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
Abschluss
Sean Kelley
387 Reputation
4 Anleitungen geschrieben
Clemson, Team 5-4, Hunter Fall 2021 Mitglied von Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare zur Anleitung
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Antwort Teilen
Ditto - where can we get a screen??
Ben Wallbank - Antwort Teilen
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 1,505
