Zum Hauptinhalt wechseln
Gateway W350I Display Replacement
Was du brauchst
  1. Gateway W350I Display Replacement, Battery Access: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: Schritt 2, Bild 1 von 3 Gateway W350I Display Replacement, Unlocking the Battery: Schritt 2, Bild 2 von 3 Gateway W350I Display Replacement, Unlocking the Battery: Schritt 2, Bild 3 von 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: Schritt 3, Bild 1 von 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: Schritt 3, Bild 2 von 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: Schritt 4, Bild 1 von 2 Gateway W350I Display Replacement, Separate Plastic Casing: Schritt 4, Bild 2 von 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: Schritt 5, Bild 1 von 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: Schritt 5, Bild 2 von 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: Schritt 6, Bild 1 von 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: Schritt 7, Bild 1 von 2 Gateway W350I Display Replacement, Remove Video Cable: Schritt 7, Bild 2 von 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: Schritt 8, Bild 1 von 2 Gateway W350I Display Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 4-1, Brown Fall 2014 Mitglied von USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
It was very easy to follow.
Very friendly guide.
Stephan Williams - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 1,341
