Zum Hauptinhalt wechseln
Goal Zero Rock Out 2 #94007 Speaker Repair
Was du brauchst
  1. Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 1, Bild 1 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 1, Bild 2 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 1, Bild 3 von 3
    • Power off your speaker before beginning disassembly.
    • Use a 2 mm Allen Key to remove eight 13 mm screws from the faceplate.
    • Use a spudger to remove the faceplate and set it aside.
  2. Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 2, Bild 1 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 2, Bild 2 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 2, Bild 3 von 3
    • Remove the gray center piece and yellow rubber lining.
  3. Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 3, Bild 1 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 3, Bild 2 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove four 12 mm screws from the speaker body.
    • Unzip the speaker case.
    • Turn the the speaker over so the bottom is facing up.
  4. Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 4, Bild 1 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 4, Bild 2 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 4, Bild 3 von 3
    • Remove speaker from cloth case.
  5. Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 5, Bild 1 von 2 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 5, Bild 2 von 2
    • Hold the speaker and gently separate the two parts.
    • Don't yank or pull it apart as the two halves are connected by cables.
  6. Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 6, Bild 1 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 6, Bild 2 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 6, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 12 mm screws securing the center resonator.
    • Carefully remove center resonator from the enclosure.
  7. Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 7, Bild 1 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 7, Bild 2 von 3 Goal Zero Rock Out 2 #94007 Speaker Repair: Schritt 7, Bild 3 von 3
    • This step requires soldering. Soldering can cause injuries such as burns to the skin. It can also produce fumes that are harmful so working in a well-ventilated area is advised.
    • Use wire strippers to remove about 6 mm of insulation from the detached speaker wire.
    • Set the soldering iron to 350 degrees.
    • Add solder to the tip of the iron and then touch the tip to exposed wire.
    • Join the wire with the electrical contact on the speaker.
Abschluss
Ricardo Arevalo Castaneda
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 8-6, Grodsky Spring 2024 Mitglied von CSU Los Angeles, Team 8-6, Grodsky Spring 2024
CSULA-GRODSKY-S24S8G6
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 77
Insgesamt: 1,004
