Einleitung
A guide to disassemble Google Home Mini for further repairs.
Was du brauchst
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
How did you get the rubber base off of it?
There’s a little more explanation here
