Zum Hauptinhalt wechseln
Google Home Mini USB Power Port Replacement
Was du brauchst
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: Schritt 1, Bild 1 von 1
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: Schritt 2, Bild 1 von 1
  3. Google Home Mini USB Power Port Replacement: Schritt 3, Bild 1 von 1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: Schritt 4, Bild 1 von 1
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: Schritt 5, Bild 1 von 1
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: Schritt 6, Bild 1 von 2 Google Home Mini USB Power Port Replacement, USB Power Port: Schritt 6, Bild 2 von 2
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: Schritt 7, Bild 1 von 2 Google Home Mini USB Power Port Replacement: Schritt 7, Bild 2 von 2
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: Schritt 8, Bild 1 von 2 Google Home Mini USB Power Port Replacement: Schritt 8, Bild 2 von 2
    • Remove the board.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Mia Sulaiman
1.032 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G4, Harley Spring 2018 Mitglied von IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Mitglieder
5 Anleitungen geschrieben
8 Kommentare
Where I can buy micro USB PCB ?
so_ang - Antwort
Planet Carl - Antwort
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Antwort
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Antwort
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 62
Insgesamt: 6,122
