Einleitung
This repair guide was authored by a member of the iFixit community and hasn’t been endorsed by Google. Learn more about our repair guides here.
In this guide, we are going to replace a Google Pixel 2 rear camera lens glass. Note that this is a glass replacement, not a lens replacement.
Take caution not to scratch the lens when removing the glass in Steps 2 and 3.
Was du brauchst
Blow dry the broken or scratched rear lens glass until it is a little bit too hot to touch.
Apply the clear silicone waterproof sealant after the lens frame is neat and clean.
Use a wooden toothpick to gently apply the silicone sealant to the ledges of the inside shelf of the lens frame.
Remove excess silicone from the edges using alcohol wipes. Make sure the lens is leveled evenly and flat.
The Google Pixel 2 rear camera glass replacement is a difficult task to do and being extra careful is a must or lens can be damaged.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
