Einleitung
The display on the Google Pixelbook is secured with strong adhesive and requires some careful prying to separate it from the case. Using heat from a hairdryer, or an iOpener, may help soften the adhesive for easier removal.
Was du brauchst
Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
Peel the linings off completely until the back of the Pixelbook looks bare.
Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
Open the back panel completely and lay it flat so you see the whole inside of the computer.
Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
Remove the small, black casing by using the spudger to lift it up from its place.
Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
Your back panel is now free from the main component.
Use an iSclack, or suction cup, to lift up the corner of the display from the case.
Insert an opening pick into the gap between the display and case.
Repeat this procedure on other side.
Use the pointed end of spudger to flip up the small locking flap on the ZIF connector.
Remove the display ribbon cable from the socket.
Use the pointed end of a spudger to flip up the small locking flap on the ZIF connector.
Use a pair of tweezers to grab the clip on the display connector and swing it over to the other side of the socket.
Pull on the clip to disconnect the display.
Remove the display.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
Where would you find a replacement display?
